How do you get the drive to show up (not grey) in vcd easy?
You need to install the ASPI-Layers for your O.S. You can download the ASPI-Layers in the Tools section. You will need the ASPI-Layers to burn VCDs' with most authoring software. VCDEasy requires you to have the ASPI-layers installed or CDRAO (a burning application which VCDEasy uses) will not work.
Hope That Helps!!! :P
CD recognition
By North in forum Software PlayingReplies: 1Last Post: 14th Mar 2011, 15:11 -
Verbatim 94554 CDR vs. 94712 CDR. What's the difference?
By Puppets86 in forum MediaReplies: 12Last Post: 3rd Oct 2010, 17:31 -
Video Recognition SW
By grishashvili in forum LinuxReplies: 1Last Post: 21st Sep 2009, 03:20 -
Can Avast cause loss of drive recognition?
By bevills1 in forum ComputerReplies: 13Last Post: 3rd Jul 2008, 04:02
