I decided to make a new post even though it relates to "My recipe for creating awesome-looking VCD's" (http://www.vcdhelp.com/phpBB/viewtopic.php?topic=48818&forum=9&15) because there is already a lot of different information and questions and I don't want this one to get confused with the rest.
OK the question-
How big is the avi file that is being created? I have a movie ( about 50min and 10gb) which i was trying to conver to avi. Does avi take up more space than mov, less space or about the same?
thanks
JB
AVI is just the file format. The size is determined by the codec used.
Im not exactly sure what a codec is. Im using quicktime 5 to encode the movie. Is that what you mean by codec? In which case do you know if quicktime encodes the files bigger than the original movie?
Thanks-
JB -
Forget my stupid question- it was easy to find the answer!
I converted a smaller mov file to avi and i see it takes up the same amount of space!
JB
[Help] Problems creating VCDs.
By scott274 in forum Newbie / General discussionsReplies: 77Last Post: 15th Jul 2008, 03:43 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 03:52 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 11:38 -
extracting jpegs from vcds
By pk475 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 9th Aug 2007, 11:38 -
Awsome Time Machine style Apple retrospective
By orchid34 in forum MacReplies: 3Last Post: 22nd May 2007, 04:43
