I have an Ibook and Im running OS X 10.1.5, and every time I try to open afropic it unexpectedly quits. Does anyone know why? I have mediapipe installed and it quits as well when I try to open it. Thanks in advance, JAT
welll thats kind of strange.. afropic SHOULD work fine on 10.1.5 (im runnin 10.2.2 so no means to test) only thing i can think of is whether or not you have the developer tools installed (which i didnt think was necessary from 10.1.4 on but i could be wrong..) now why mediapipe quits on you i havent the faintest, it should still RUN w/o the dev tools.
As below, so above and beyond, I imagine
drawn outside the lines of reason.
Push the envelope. Watch it bend.
Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind. -
I am having a weird problem too.
It says:
File not open with write permission. (-61)
How can I fix this?
Qshartle"Good Luck 007"
In Memory of Desmond Llewelyn -
copy the file off of the disc image to get rid of that error-- its because a shell script is imbedded inside the program and if you dont have write permission (which you dont when its still on a disc image) then you will get this error-- the next version will not be riddled by this problem.. mainly because im going to discontinue putting it out on disc images till i fix the problem.
I did this and it fixed that error.
Now it is not finding the video file. it just encodes the audio.
Thanx
im going to need more info than that... like the terminal output or the shell script to have any idea what the problem is
