When i try to rip the matrix it rips it in split screen instead of widescreen! Does anyone know how to fix this ?!?! If you dont know what this means it is.... When you make ur windows media play full screen only half the screen is taken up with the movie and there is a big black line going across the bottom and the top! I know y'all know what split screen dvds are.... Thanks
What the F**K is a split screen DVD??????
What you're viewing IS a widescreen picture. That's why ther's black bars at the top & bottom. Hence the term W I D E screen.
Sorry, didn't mean to be rude. Unless you have a 16:9 TV or monitor you'll ALWAYS have black borders at the top & bottom of the picture. Otherwise the sides will be getting cut off. -
Humm Sully... You da man!
One day, everyone will absorb some terminology.
<hr>
Well vested in the following: Pinnical DC-10+, TMPGEnc, AVI_IO, VirtualDub, Flask, BBMpeg, SmartRipper, DVD2AVI
<hr>
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 17:23 -
Wide screen
By breeze9 in forum Newbie / General discussionsReplies: 1Last Post: 8th Dec 2007, 22:31 -
DVD picture doesn't fill screen on new wide-screen TV
By ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2007, 03:37 -
converting wide screen to full screen. HELP!!
By arjunkkalra in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jul 2007, 12:41 -
wide screen
By ht0160 in forum Authoring (DVD)Replies: 16Last Post: 18th May 2007, 16:52
