Hi there,
I'm looking for a DVD player which can play DVDs from all regions, or a way to make a DVD player to be able to play DVDs from all regions.
Zzyzx
Results 1 to 13 of 13
Try Koss DVP-2161 (12V, need firmware hack) or Daewoo DVD-5800 (remote control hack,110V or 220V). I tested both in US (110V) with Region 1 (NTSC), Region 2 (PAL) and Region All (PAL) DVDs on NTSC TV. For more info look into "DVD Players" section here.
i had a classic dvd player that i bought from toys r us. it had the option of switching regions thru the menu screen.
These are the currently available players I know of that can be made region free using only the remote:
CyberHome DVD-402 - $70
CyberHome DVD-500 (Progressive Scan) - $80
Daewoo DVD-5800 - $80
Norcent DP-300 - $80
There are other brands and models that can be made region free and even Macrovision free, but they require creating a CD that reprograms the player. -
get an apex (I use the 1500) and burn a CD to remove the region restriction (if you do a search here you should find the web site that has the images to d/l, they are only a few kb if I remember)
pop in the CD, and it runs itself.
Andy
Don't you need to make your DVD-ROM region free for this ?Originally Posted by drewson99_99
I mean, why copy DVD to CD when you can have DVD-Player that plays all DVDs. Too much work and worst final quality.
No the Apex-1500 becomes region-free (and macrovision-free) by changing the firmware. This firmware "upgrade" is made by making a CD-R which contains the hacked firmware. This is explained on www.nerd-out.com
Others players have region free remote hacks. For example, the Philipps DVD-724 has a region-free remote hack. -
Sir, you are misunderstanding both myself and yg1968 (who does understand what I am saying, by the way.)
If you go to nerd-out, like he said, you'll see the hack I'm talking about.
1) you d/l an image.
2) you burn the image to CD
3) you pop it into your APEX 1500
4) it runs
5) your APEX 1500 is now region free for all disc types, DVD, VCD, SVCD, whatever.
Andy
Got a GE 5803P, 3 DVD changer. Got it for 100$ or so. Region free, macrovision free too. Lots of players do that... Mostly all shinco clones.
Need to decode Sony DVD to play all regions
By Rhonda in forum DVD & Blu-ray PlayersReplies: 3Last Post: 22nd Apr 2011, 23:36 -
Can play region 3 and 4 DVDs--can assume the same for other regions?
By glache in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Dec 2010, 05:17 -
Regions: Sony DVP-SR90 CD/DVD player
By Marvinshadow in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Oct 2010, 12:22 -
Look for DVD player that can change from region 1 to all regions
By plk1758 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 19th Feb 2010, 11:27 -
Can a dvd player that able to play dvd+r dl play dvd-r dl or does this vary
By dymx in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Oct 2007, 15:33
Yep ! You are right. My fault. Sorry.
