Hi,
Im using VirtualDub and TMPGEnc for putting subtitles on my movies
so i can burn them to VCD-discs.. I have a minor problem getting it
work correctly.
The subtitles seems to be out of sync.. The thing is if i directly watch the
DivX movie in Windows Media Player with the subtitle it's no problem.
The subtitles work fine and are in sync.. BUT when im frameserving it to
MPEG the subtitles are NOT in sync..
Some movies are no problem framserving with subtitles.. But most movies does'nt work... I get the titles in the MPEG file but they don't display when they should..
Someone knows what to do?
When you watch your movie in mediaplayer before converting it to mpeg, it probabely is Vobsub that displays you subs. Me also I have noticed that the display by vobsub usually is more accurate then after conversion.
Here's a guide on how to sync your subs:
http://www.vcdhelp.com/forum/viewtopic.php?t=114509&highlight=
It only works if the subfile is in srt, smi or sub format. If it isnt, just go to some search engine and type for example SSA2SRT(If the subfile is SSA).
J
Subtitles problem !
By mathbes in forum Blu-ray RippingReplies: 1Last Post: 17th Sep 2011, 16:39 -
Another Subtitles Problem
By Djanarak in forum Video ConversionReplies: 4Last Post: 5th Jun 2011, 05:30 -
Problem with subtitles
By romanvida in forum Authoring (DVD)Replies: 1Last Post: 4th Oct 2010, 14:38 -
Magix movie edit 16 - audio/video unsynced
By Empet in forum EditingReplies: 0Last Post: 4th May 2010, 12:11 -
Problem with the subtitles
By empana in forum SubtitleReplies: 2Last Post: 11th Nov 2008, 04:54
