I have tested and reviewed the wintv pvr card but as my english is far from good would I You to check that you understand what I have written before publishing it for all.
http://www.vcdhelp.com/reviews/wintvpvr/pvr.htm
<font size=-1>[ This Message was edited by: Baldrick on 2001-08-25 09:11:56 ]</font>
Nice review Baldrick, another one to cross from the list.
Really appreciate the work that guys like you put in to help guys like me.
{Just to remind you, that on the 28th February 2002, the Turnip ceases to be legal tender in Europe!)
[quote]
Hi:
What kind of system are you using? I've switched from a VIA Chipset K6-2 500 to a PIII 450 using a WinTV PVR with lousy results as far as dropping frames and sync are concerned. I can't figure this stupid thing out. I've tried everything, even changed to a PCI audio card. I don't know what's causing my buffer underun erros in the encoded video stream, as reported by tmpeg, after muxing it to be able to get the right file size in NERO. Also NERO wont take it until after I mux it. I've tried different video sources. Any ideas? When my parallel port DAZZLE worked (it's interface took a break) I was making great videos. These new fangled TV cards are pretty hyped as far as I'm concerned..., unles you spend like the pros.
Regards, flyboy -
"What kind of system are you using?"
A P3 750
Intel®440BX chipset Abit BE6
512MB RAM
Soundblaster Live
Win2K - Service Pack 2
And havent have any problems capture problems...so far.
"Also NERO wont take it until after I mux it."
Thats so for all, you have to mux it with right VCD or SVCD settings. -
flyboy the WinTV-PVR dosen't have the Multiplex features buildin.
The Visiontech Kfir MPEG chip is ture MPEG1,2 Stream encoder.
A small review of Hauppauge MPEG Editor vs Womble Multimedia Mpeg2vcr.
Just give you idea of the time it took 35+min to do this 1+GB file with Hauppauge MPEG Editor no cuts where Womble Multimedia Mpeg2vcr took less 5min to do with no cuts.
But I have say it is by far fast of then any other MPEG1,2 Editor I have ever seen unlike Adobe Premiere 6.0, Ulead VideoStudio 5.0, Ulead MediaStudio Pro 6.0, Mediaware M2-edit Pro 4.0, Sonic Foundry VideoFactory 1.0, Sonic Foundry Vegas Video 2.0 all other want re-render the entire movie ekkk.
And yes the Hauppauge MPEG Editor dose the Multiplex on the fly so all have to do drag and drop in to Nero 5 VCD template.
If you are having problem with the Hauppauge MPEG Editor being out of sync in audio after edit it I think found the problem more on that later still doing testing.
Note there is major problem with MPEG2 one thing you should due is run "Hauppauge PVR PCI Utility" before recording an video this help in getting the best quality out of it even I keep forget to this, I guest Hauppauge hasn't build this in to WinTV2000 to do on the fly.
Nice have you board Baldrick, Baldrick as for the PVR problem it real.
1) Algorithm artifacts in fast sceans in the recording above MPEG1 VCD.
2) Small blockless in fast sceans MPEG1 and MPEG2 under cartoon and reg movie or TV show, but dose help if you run the Hauppauge PVR PCI Utility and reset & update the hardware before recording any thing.
3) Noise around objects in MPEG1 and MPEG2 under cartoon and reg movie or TV show.
4) 480x480 SVCD or 640x480 not in the rigth frame size a nice big black bar on rigth (NTSC).
deadrats' review of the i3 2100
By deadrats in forum ComputerReplies: 11Last Post: 26th Oct 2011, 21:16 -
VIXIA HF S21 Review Anyone?
By MayorMacCheese in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 18th Jun 2010, 05:39 -
best review of Avatar, ever.
By deadrats in forum Off topicReplies: 0Last Post: 14th Mar 2010, 15:33 -
New Build -- Please review!
By Deku Scrub in forum ComputerReplies: 17Last Post: 11th Nov 2009, 07:05 -
deadrats' review of the E7400
By deadrats in forum ComputerReplies: 2Last Post: 11th Apr 2009, 20:31
