I was doing all my capturing via a ATI TV Wonder VE card. Now that card finally has died out. And I noticed on this camera:
Mini DV Hanydcam Vision / DCR-TRV900
That there is a dv in/out port, look like either a firewire / usb port. Now, can you use this to capture video, WITHOUT a card? or how does this work?
Im very new, so any information would be greatly appreciated!
Results 1 to 9 of 9
Nearly, all DV cam has firewire port, which is a very high speed serial transfer to/from your computer.
You need to make sure you have analog pass thru, that uses your DV cam as a capture card. -
I looked up more information on this camera .. and I noticed that it uses:
I.Link DV Interface .. know anything about these? -
OK, I see. So I need to purchase a capture card that takes Firewire plugs. correct?
Thanks for helpin out. -
Yes, you need to buy a firewire card with software and cable.
Make sure the DVcam you pick has "Analog Passthru".
I mixed my old Hi-8 capture and miniDV capture, on the same VCD. They are seamless, pretty good. -
The vid cam I mentioned above is the one I have .. dunno if it has "Analog Passthru" I'll have to check out the specs.
thanks for your support
any firewire card you suggest? -
Just about any firewire card will do. You are better off buying one that comes with a firewire cable as you will also need a cable.
Your camcorder has passthrough. See this link:
http://www.sel.sony.com/SEL/consumer/ss5/home/handycamrtmcamcorders/minidvcamcorders/d...00_specs.shtml
You must remember to enable dv out on the camcorder's menu in order to capture from your camcorder. You can Windows Movie Maker or DVIO (or many other programs) to capture DV.
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 12:42 -
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 11th Jun 2011, 00:05 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 19:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 20:42
