Is there anyway I can copy DVD perfectly (or as close to perfect as possible?)
I'm not concerned about fitting on one disk
I do want menus, sbutitles etc
I would prefer to keep surround sound.
I work in a Library, and we are permitted to back up videos so long as only one copy is in circulation, so copyright is not an issue. But we need to protect our investments, as patrons will scratch or break our videos, and purchasing new ones for circulation can be up to 500% of the consumer price. HELP!
Tak a look around this site and maybe www.doom9.org. There are numerous guides and many freeware tools that will do pretty much what you want. About the only problem you will have is that many commercial DVD's are double layer and up to 9.4 Gig caopacity where as recordable DVD (+-R(W)) is only single layer and so only 4.7 gig capacity. If your source is too big you can either re-encode or split it over two disks. As I said, take a look around and find a guide/method that suits you.
Exact maximum capacity of DVD+R
By geohei in forum Authoring (DVD)Replies: 18Last Post: 21st Mar 2009, 09:23 -
Exact copy of a DVD to a container playable in itunes
By jamsponge in forum DVD RippingReplies: 5Last Post: 20th Jan 2009, 10:19 -
How to make exact screencaps easily from DVD?
By zee944 in forum Software PlayingReplies: 30Last Post: 8th Aug 2008, 03:06 -
how do i convert the exact same AVI file to DVD on avidemux?
By whodini in forum Newbie / General discussionsReplies: 4Last Post: 20th Jan 2008, 19:14 -
DVD copies
By JimboS in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 22:33
