  1. I've been downloading some clips that are weird sizes, and I'm not quite sure how to convert them to play as a svcd (or vcd for that matter). I've got one that is 496 x 384, 464 x 352, etc. Could anyone explain what settings I want in tmpg to get it to burn right? I'm confused with the stream source and video source sections. Thanks for any help.
    Mar 2002
    United States of America
    Go Under the Video Tab and next to Aspect Ratio, set it to 4:3 (PAL or NTSC). Also, under the Advanced Tab, set the "Source aspect ratio" to "1:1 (VGA)" and the "Video arrange method" to "Full screen (keep aspect ratio)". Also, before you perform any of those steps up there, select the template that you're encoding to (SVCD or VCD-PAL or NTSC depending on where you live) and there it is!!!
    Hope That Helps!!! :P
    Mar 2002
    LucasBuck, did that help you understand? :P
