HI!
Im a total nOOb in DVD-Ripping.
I tried to though, usin' several guides. But i got the following problem: Can somebody tell me how to eleminate those black bars at top and bottom?
I mean if you got a 16:9 movie and you want to rip it, is it necessary to have those black bars???-if you "cut" them off, the files would get smaller, dont they?
I used smartripper to get the dvd files and encoded it with DVDx.
But how can i get rid of those dem' black bars???Would be nice if someone tells me...![]()
well on my tv i have a zoom feature that makes those black bars go away. maybe yours dose to,
what about cropping???
but if its wide screen it will strech top to bottum.
or turn the dvd over and rip the full screen(if you can) :P
i'm kinda new at it to,so i'm not sure if i know what i'm talking about -
for a 16:9 movie if you want to watch it how it should be watched you have to have the black bars. Otherwise you have two options, either stretch the video then everything looks too tall, or crop off the edges and zoom into the area you haven't cropped. I couldn't tell you how to do either of these things because I would never want to do either. Most full screen movies are cropped and zoomed in but the area that gets cropped can move around and pan to the area of the screen with the most action. If you crop it yourself you might run into a screen where the action is on one side of the screen that you cropped off and you'll completely miss what is happening. Read this if you want to learn more http://www.doom9.org/index.html?/aspectratios.htm. Taking out the black bars has nothing to do with filesize. the only thing that will affect filesize is bitrate and changing that affects quality too.
With DVDx you should use the zoom funtion this will reduce the black bars
file size will remain the same.I normally use med zoom or panscan if anamorfic wide screen. -
Also, from what I have read the Black bars dont take up much data space in your rip and conversion anywayz. Might wanna keep them.
HIde -
Oh I see...
The arcticle on doom9 really helped me alot. Very good stuff there!
I thank you guys
Adding black bars
By ebay in forum Video ConversionReplies: 4Last Post: 7th Aug 2010, 04:37 -
Black Bars
By cinnamonhearts2 in forum Newbie / General discussionsReplies: 15Last Post: 30th Jul 2009, 12:44 -
black bars or not?
By Cowabunga in forum Video ConversionReplies: 6Last Post: 16th Apr 2009, 12:56 -
Need to cut off black bars
By Dozza in forum EditingReplies: 8Last Post: 2nd Sep 2007, 07:17 -
Black bars fluctuating...
By FallenAngelII in forum Newbie / General discussionsReplies: 5Last Post: 16th May 2007, 14:04
