  1. I'm trying to copy some dual layer dvds to dvd-r, can't figure out how to do it. Each DVD has 6 or 7 episodes on it, and each ep has its own VOB, so its like 6 movies on each disc. Can I split them up or reencode them with the usual tools (infoedit, tmpge, ect..)
    Any ideas?
  2. Satanking you could try using this software called dvd2dvdr you can check it here
    http://www.vcdhelp.com/forum/viewtopic.php?t=124578
  3. Thanks I'll have to give that a try. Also I should mention that I'm using Nero to burn.
  4. I was thinking the same thing, but in addition I would like to keep some, yet not ALL, of the episodes of another TV series DVD. I was looking at doing it like something this:
    1. Rip Each DVD to large .m2v & .ac3 files
    2. Merge into MPEG file with TMPGEnc MPEG Tools
    3. Load the MPEG into TMPGENG and crop out the episodes I want and re-encode to compress a bit
    4. Load MPEG's into Ulead Workshop and Author
    I would rather load into Maestro as I am pretty familiar with it now and it seems more effiecient in compiling. Anyone know how I can either split the .m2v files or import the MPEG files into Maestro?
    rhuala
