I just got an A04 but might swap it for an A05 for better value in the long run.
I know the 2x Ritek's work well at 2x with the A04 FW 1.31 so I plan on ordering 50. However if they don't work at 2x with the A05 that would be a bum deal!
TIA
i'm curious about this as well, I need to get some good media...are you talking about the Gold/Purple ones?
I think so, these are those I'm referring to:
http://meritline.com/rithigqualgo.html
Just noticed this though:
"1x if you have other dvdr drives or other version of Firmwire"...so I guess they don't guarantee they will work at 2x with the A05... -
well, i would think that since the A05 is the upgrade from the 104, it should work, but then again, i'm not sure, as i'm new to this whole dvd-burning process, just got my 105 a few days agoOriginally Posted by bumblebe
but if it does work, it would be a good deal for some good DVD-Rs -
not sure I would assume that since A-4 with 1.32+ doesn't burn them at 2x...
Also I wonder why the (same?) Ritek's that allmediaoutlet has aren't rated at 2x... http://www.allmediaoutlet.com/P-DVD-R-4.7-R100free.html
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 23:13 -
Where Are these Ritek CD-Rs Made???
By NBK2 in forum MediaReplies: 19Last Post: 19th Aug 2010, 14:32 -
Pioneer BDR-205 requires HD video card to work??
By lafjax in forum DVD & Blu-ray WritersReplies: 4Last Post: 1st Jan 2010, 12:51 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
Ritek: NEVER EVER AGAIN
By mrlar2 in forum MediaReplies: 50Last Post: 15th Aug 2007, 04:13
