i was wondering if anyone knew what this was? the longer my captures are in vdub the larger this gets? i feel a need to correct whatever its telling me to adjust (and the audio does seem a little out of sync w/ these numbers increasing). the picture below doesnt show it too bad (being a very short capture... but you get the idea.
does anyone know what this means and how to correct it? ive tried virtual dubs website, the help files, etc.. and no answers?
thanks for any help
jerets
or
http://www.webspawner.com/users/2gss6a/capture.JPG
This tracks the ammount of difference between your video capture device and your audio capture device.
For the most part video is 29.97 ( unless you are taking VHS and the signal gets worn over time ). Your audio card cannot always provice you with perfect 44,100 samples/sec. Virtual dub keeps track of everything based on the audio rate and then just adds duped or dropped frames to keep up with it.
From your picture it's apparent that your audio device is capturing almost 100 samples/second too many. Over time this will mean that vdub will have to insert duped frames for the audio and video to stay within sync. -
sweet. i appreciate your reply
, but do i need to set any options (or make sure theyre already set) either before the capture or beforing editing (b/c i re-endcode after i edit) to correct this?
i appreciate your response
thanks
jerets -
It uncorrectable, it's just your hardware.
Almost every system where the audio and video are seperate systems has some sort of drift in the capture. -
ya my main concern here is to keep the audio and video in sync... the longer the capture goes the more out of sync it gets (slowly but surely)... in 45minutes the "VT Adjust" will be up to +300. im still pretty unclear what this means. i understand a can't correct it but when i re-encode... or in any of my settings is there anyway to insure that the an adjustment is made to make sure that the audio and video are back on track?
i appreciate your help
thanks
jerets -
VirtualDub should by default ( I think it's been a while since I touched any settings ) keeps the audio and video in sync.
Check out the documentation for the fix. -
You may also want to try a Virtual Dub modification, Virtual Dub Synch (http://www-user.rhrk.uni-kl.de/~dittrich/sync/), which is supposed to handle audio/video synch in a more sophisticated way.
i thank you both
thanks so much for the helpful replys.. ill let ya know how it goes =)
thanks so much
jerets
VDub "incompatible data formats" error
By coyote2 in forum EditingReplies: 10Last Post: 1st Nov 2011, 12:28 -
VDub "add to job control" option...not there anymore?
By CursedLemon in forum EditingReplies: 2Last Post: 17th Nov 2009, 10:47 -
What Vdub filter can get rid of the green "Ghosting"?
By Brainiac in forum RestorationReplies: 5Last Post: 3rd Sep 2009, 19:08 -
vdub "blend" deinterlace works, but now lines are jagged
By italo4ever in forum Video ConversionReplies: 3Last Post: 29th Jun 2009, 23:35 -
question about "save old format avi" with Vdub
By mr-scarface in forum EditingReplies: 3Last Post: 5th Sep 2007, 22:34
