See the dvd is full screen so i dont know why its not ripping it full screen?!?!?! If anyone could help me with this please get back too me ! By the way i am using smart ripper.
Results 1 to 9 of 9
define "cut" screen. and how can you tell what they look like if all youve done is rip it so far?
well see cut screen is were you how a black thing going across the top and across the bottom. I wanted to rip it full screen (wide screen). My friend did it so i know i can do it someway.
actually that is letterboxxing, but anyways. It has to do with your setting under the advanced tab like source aspect ratio and your video arrange method mess with those and im sure you'll get it.
could any one tell me these settings. I get kinda dumb some time when it comes to these things ! this would be a awsome
help! Thanks -
right. you're very confused. if you're 100% sure your DVD is fullscreen, 1.35:1 or 4:3, depending on whichever you prefer,
actually, im fed up of typing this stuff over and over. read the guides, experiment. it's not hard. -
All my friends told me it should be full screen, Are there some ways of checking? And i dont know what things to read up on. So if someone could give me a hint plz do
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
yes, you can play the dvd in your stand alone player. if you can play it 4:3 full screen, then you can rip it full screen. otherwise you can't. it's not the primary track if it's full-screen 4:3 on the dvd -
Is there any way of changing it to 4.3 ? Thanks cus its not playing it full screen. By the way on the cd it says widescreen... does that mean full screen. Thanks | T/m |
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 17:42 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 15:43 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 17:23 -
DVD picture doesn't fill screen on new wide-screen TV
By ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2007, 03:37
