I am looking another DVD player to play movie in another room. My first was a Pioneer DV333, that cost $170 from B.B. The newer model from Pioneer has aspect ration issue with SVCD.
I saw the spec and review of JVC XV-S300BK. It look good, and also have tha same minor that DV333 has : you need to flick a switch between component and Svideo/RCA output. I also see quite a few problems about SVCD playback bitrate. Pioneer also has the same limit.
I do like the digest, storbe features, and the low cost of $100.
For those we already own one, will you recommened it ?
This is only the second DVD player I've had so I don't have much to compare it to.
Plays VCD and SVCD really well, provided you get the fps right - the UK version likes 25 fps but not 23.97fps.
Don't know about DVD+/- R/RW compatability, but I presume it can read all types of disk.
The only problem is that it doesn't show the time during VCD/SVCD playback, but then that's hardly a big issue.
On reflection, I think I would buy it again unless there was another player that was available which had more features.
Rob -
I also purchased the JVC, it is a second unit (my first is a Sony 500D).
For burning I've got a HP200 and the JVC has no problem with the +R's and +RW's.
The JVC plays pretty much everything I put in it (wish I could say the same for the Sony) but won't play miniDVD's and won't play MP3's burned on DVD. Neither of those are really a problem and I understand that most units will not play either anyways... -
Would. (I actually have XV-S302, but only difference is case color) To correct one thing - it shows VCD/SVCD playing time, but ONLY, if playback is started from number buttons. Plays DVD-R/RW without big problems (some skips with cheap RW and up to unplayable with early cheap R). Todays cheapos play to the end. No problems with CD-R(W). Can't exceed SVCD bitrate (skips at peaks).
So far, look like standard SVCD is working fine with this model.
I was worry a bit about quite a few members reviewed not able to play their disc, I kind of think this model behaves like pioneer : It does not work well above 2520 bit rate.
VCR Comparison: JVC SR-W5U vs JVC SR-V101US
By robjv1 in forum RestorationReplies: 18Last Post: 22nd Apr 2021, 04:36 -
JVC HM-HD30000U For Sale - JVC Refurbished!? What?! :)
By jbd5010 in forum Capturing and VCRReplies: 7Last Post: 22nd Jan 2011, 21:30 -
JVC SR-MV55US - Users with Experience with JVC Professional S-VHS/DVD Decks
By Anonymous4 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 21st Aug 2008, 16:23 -
Whose got a JVC HR-S9600U I can buy?
By Endzone in forum Capturing and VCRReplies: 4Last Post: 8th Mar 2008, 04:16 -
Should I BUY the Canon HG10, JVC GZ HD7 or JVC GR HD1 ??????
By thecuban in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 27th Dec 2007, 13:40
