plz help!
While i was converting mpg or avi to VCD using TMPGEnc and error had appeard: Stream writing error.
what should i do??
I think you should me a bit more specific about the tools you use and the movies you are dealing with. Use Virtualdub file information for a pecise answer, watch for audio framerate, resolution.
The info you gave could mean anything -
i chaked in Virtualdub for file information :
video stream:
frame size fps- 640*272, 23.976 fps
#of frames- 122,813
Decompressor- Dvix 5.0.2 codec
number of key frames- 1452
min/avg/max/total key frames size- 857/15093/63430
min/avg/max/total delta frame size- 87/5022/68/721
audio stream:
sampling rate- 48,000 Hz
channels- 2(stereo)
sample precitions- 0-bit
compression- fraunhofer ||S MPEG layer 3 codec
preload skew- 480 sampels
# of frames- 213,428
min/avg/max/total frame size 192/432/960 -
I had the same problem
Its the audio.
demultiplex with vdub ( audio direct stream copy, file save waw)
that file will be an MP3 ( fraunhofer)
get beesweet
open the file in beesweet, (check FRC ntsc2pal if you live are making PAL discs ( check your fps!!)
convert the file to waw ( you dont really need to touch anything else, maybe resample to 44.1kHz)
get back to tmpeg and continue your conversion.
This might sound a bit complicated, but its not that, really.
Converting .mpg movies
By baysee in forum MacReplies: 14Last Post: 25th Sep 2009, 06:11 -
Trouble converting mpg
By Jeffrey99 in forum Video ConversionReplies: 4Last Post: 13th May 2009, 06:59 -
Converting .ts to .mpg (HD)
By tomerwiz in forum Video ConversionReplies: 7Last Post: 8th Nov 2007, 14:48 -
Converting a mpg file
By galehickey in forum Capturing and VCRReplies: 5Last Post: 28th May 2007, 09:03 -
Converting WMV to MPG
By Datahead in forum Newbie / General discussionsReplies: 3Last Post: 22nd May 2007, 14:08
