Results 1 to 11 of 11
  1. how many dual layers DVDs actually have the movie being less than 4.3 gigs? I've tried loading up a few movies into DVD decryptor, and when it selects the main movie files, the total selection usually comes out around 5-7 gigs...what movies have actually been done by just stripping everything but the main movie, and without re-encoding?
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
  3. Thank You very much for this exact number! No, wold You, please, be so nice and list them!
    IMHO it is even harder to say, when no system is stated. Common sense sais, that PAL needs roughly 25% higher bitrate for its higher framerate (for filmed material) and resolution, so less 4.3 Gig movies in PAL.
  4. Ask this similar question before, the answer is about 60%. See :
    http://www.vcdhelp.com/forum/viewtopic.php?t=124233&highlight=reencoding
  5. thanks for the replies...and thanks SingSing for that link, it helps out a little bit...i'm gonna go load some more DVDs in and see if any of those will work without reencoding
  6. Originally Posted by pimp97max
    it's kind of strange that you have dual layer dvd that is only 4.3 Gigs... DVD-5 would be much cheaper to manufacture...?
    Zzzzzzzzzzz
  7. Член BJ_M's Avatar
    Jul 2002
    Canada
    yes - it costs 70-93cents less to make dvd5 than dvd9 in bulk . which adds up to a lot a money on say 200,000 copies ..
  8. hey, just so ALL of you know, goldmember is under 4 gigs
    its using VBR, so all can rip with subs,which dont work,and
    menus + a few extra + britneys boys video if you want....
  9. Originally Posted by Scobo
    thanks a bunch for that link
  10. I asked a question about a site like that on the "off topic" forum a couple of days ago, but got no response. I am glad to see one like that really exists. I wasn't sure when I asked that question. Lucky Me. Now I can save up and buy the DVD's I like from that site so that I can make more "back-ups." Damn!, a mosquito just flew right into my pupil...LMAO...wink, wink
