Hi
I think I need help with this. I want to convert DVD movie from NTSC to PAL. I can use Smartripper/DVD Decryptor to get .m2v & .ac3 stream. I can use TMPGenc to convert movie from NTSC to PAL but what can I use to correct the .AC3 audio to 25fps?
Can anyone help me?
As far as I can ascertain, you won't need to resync the AC3 for 29.97 to 25 fps or anything of the sort. The fact that you have converted the video stream from NTSC to PAL is a separate ideal to what you would do with the audio stream.
Essentially speaking, if the NTSC->PAL conversion does not result in a change of running-time (eg 127m53s in NTSC equals 127m53s in PAL) then the AC3 soundtrack is perfectly okay to convert to its VCD mp2 equivalent without any time-dilation processing whatsoever. Give it a try and see how it goes, but I doubt you'll have any problems. If you do, then put down a more detailed description of what you're attempting to do with the conversion.
Hope this helps.
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 15:17 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
PAL to NTSC Conversion with DD
By cottage in forum Video ConversionReplies: 5Last Post: 16th Feb 2009, 16:10 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
