  1. What do I need to capture DV form my camera? It is connected to a firewire card but VirtualDub does not recognise it. I had no problems capturing analogue but this digital video seems a bit trickier. Specifically, when I try to capture with VirtualDub I get the following.....
    "Error - can not find a driver to draw this non-RGB image format . Preview and historgram functions will be unavailable "
    Thanks,
    peejay
  2. Firewire is not a capture device, it is a File Network Transfer thing.
    WindowsXP MovieMaker can transfer over the digital DV Video.
    Jun 2001
    Virtualdub will not capture from a firewire device. Most commercial programs will though (Pinnacle Studio 8, Windows Movie Maker etc.) If you are on a budget and don't want to pay for a capture program use this:
    http://www.carr-engineering.com/DVIO.exe
    It simply captures the stream from the firewire card as a type-2 avi file. If you get this codec:
    http://www.mainconcept.com/archive/mcdv204.exe
    you will be able to open the stream and edit in virtualdub.
    Hope this helps!
