  1. Hi,
    I am authoring a VCD with vcdimager / vcdeasy.
    Is it possible to define which clip should be played when pressing the "main menu" button?
    It seems to be always the first clip on the disc by default, can I change this?
    I have a short intro clip (first play) followed by the menu,
    and now i would like the player to go to the menu when pressing the button.
    Thanks for your attention,
    Ed.
  2. I dont think the VCD standard supports the "main menu" button. I'm pretty sure that the "main menu" button is for DVD use only.
    You could however, assign a number to go to the main menu or perhaps the "return" key.
    PlaiBoi
  3. Thanks for your reply,
    Now I have found a specification of the (very few) keys for vcd:
    (only next,prev,return,default,numbers)
    http://www.vcdimager.org/pub/vcdimager/manuals/0.7/vcdimager.html#SEC39
