    Budapest, Hungary
    HI all,
    So I've an avi with fraunhofer (mp3) vbr audio. Vdub prompts as usually, that the audio is vbr and......
    So I save the waw, I put it in Tmpeg to convert it to mp2, and then tmpeg prompts: stream followin error, right at the beginning.
    What could the problem be?
    Pls help me
    May 2002
    Rainy City, England
    Some suggestions:
    1. You could try a different version of TMPG. Some are a bit buggy.
    2. Load the wav into Cooledit or Soundforge, and save out a copy, and then try again.
    3. Convert to .mp2 using HeadAC3he. (You can even try inputting the mp3 to HeadAC3he as source.)
    Budapest, Hungary
    Thanks!
    Headache seems to be working fine, later I only used that sw for ac3 decoding. Do you have any comparison xperience on the output quality of tmpeg/headac3he? I was satisfied with tsunami, I hope I'll be with this sw also.
    Anyway thanks for the solution
    May 2002
    Rainy City, England
    I have always been happy with TMPG's audio output, so long as you don't let it do the resampling.
    As to HeadAC3he - look at the .dlls it loads (lame, azid ssrc etc). They are generally acknowledged to be the best tools for the jobs they do.
