I have "Titanic" on my C drive and "Doctor Zhivago" on my D drive. The physical drive is one - partitioned.
I have ripped both movies using DVDDecryptor and DVD2AVI.
I have named the files:
Titanic: 1_pal.d2v; 1_palAC3T013_2ch384Kbps48KHzs.wav
Zhivago: 1.pal; 1_palAC3T013_2CH192Kbps48KHzs.wav
When I double click on the .d2v files, both open in WordPad and appear OK in all respects.
When I double click on the wav files, both play fine.
However when I use TMPGEnc I get a problem.
The Titanic file's output has no audio.
The Doctor Zhicago file's audio is fine.
The TMPG settings are exactly the same in both cases as far as I can tell.
Why is it that in the first case there is no audio?
I recently ripped two other movies on the C drive.
The first one ripped fine.
The second one, comprised 3 CDs. The first two CDs are fine but the 3rd has this problem of no audio.
I am baffled and would welcome help urgently (as I have 3 DVDs to rip in a tight time frame!).
Thanks in advance.
hrm...i did titanic awhile ago (region 1 though) and had a similar problem...however, for me, the .wav file couldn't play in media player as well..so it may not be the same problem...
but for me, the problem was because the .wav file was too big and tmpgenc doesn't seem to like it very much.
so, i just split up the titanic vobs into 2 groups and encoded them separately as if they were 2 movies, then you can cut/join however you like at the end.
Strange Audio Problem
By Wanderlustus in forum ComputerReplies: 4Last Post: 21st Feb 2011, 15:27 -
Strange MKV audio problem
By Captain315 in forum Media Center PC / MediaCentersReplies: 0Last Post: 21st Dec 2010, 23:00 -
Strange audio sync problem with downloaded AVI
By embreeb in forum AudioReplies: 9Last Post: 9th Dec 2008, 09:30 -
synching m2v and wav audio - strange problem
By ecc in forum EditingReplies: 7Last Post: 20th Feb 2008, 06:22 -
Strange Audio Sync Problem
By innovyse in forum Video ConversionReplies: 2Last Post: 6th Dec 2007, 14:36
