  1. Hi,
    I'm trying to convert a DiVX to a CVD. Unfortunately VirtualDub is not able to recognize the audio compression used for the file. All it reports is:
    File Information: Audio Stream:
    Sampling rate: 48000Hz
    Channels: 5 (Stereo)
    Sample precision: 0-bit
    Compression: UNKNOWN (tag 2000)
    I'd be grateful if anyone can provide any info on how to get this resolved.
    Regards: The MacMan, NL
  2. You have ac3 5 channel audio, you need to save the wav file as a direct stream copy, rename it as ac3 then use headac3he to convert it.
    http://www.vcdhelp.com/forum/userguides/91588.php
