Guys,
I've ripped Attack of the Clones PAL region 2 and need the forced subtitles and none other...how and where are they located?
I ripped using DVD Decrypter using the Direct Stream Copy mode
and am ready to encode to SVCD but I cannot find the forced subtitles...the english subs and the directors commentary subs fine...but no forced subs...the ones that pop up when the aliens are speaking alien etc...
All i want is a SVCD that plays like the DVD..the subs only pop up
when the aliens are speaking.
Is this possible and what are the steps to achieve it?
Any help would be appreciated
Waylander
http://www.vcdhelp.com/forum/viewtopic.php?t=124410&highlight=
i did region 1, so the subtitle stream where the forced captions are may not be the same...if you have use the preview feature in either flask or vdub to make sure you only selected the forced captions and not closed captions
o..in case u didn't know how to add subs..check out these:
flaskmpeg/avisynth
http://www.vcdhelp.com/dvdtovcdflask.htm
vdub/vobsub:
http://www.doom9.org/index.html?/subtitle_guide.htm
forced subtitles
By bogey219 in forum SubtitleReplies: 4Last Post: 6th Nov 2011, 21:00 -
forced subtitles question ...
By zero7404 in forum Blu-ray RippingReplies: 0Last Post: 17th Aug 2011, 21:31 -
Forced Subtitles
By sxj1704 in forum Blu-ray RippingReplies: 4Last Post: 29th Jan 2011, 08:17 -
Forced Subtitles Only In First Stream
By sambat in forum SubtitleReplies: 3Last Post: 28th Apr 2009, 22:05 -
The Mummy - How to get the forced subtitles
By Mascot in forum Blu-ray RippingReplies: 19Last Post: 20th Apr 2009, 20:01
