I have a sony 725d dvd player and many people have said princo cdr works. I brought some unbranded princo cdrs and burn one audio track at 1x and 4x and it doesnt work. what colour does the dye have to be etc. What software do u use to burn the cds and i have asf files i want to convert to vcd so what software do i use. If anyone in uk has got theres to work people tell me where u got the disks from as it would be a help. Thank you all
Results 1 to 12 of 12
i have brought some princo cdr unbranded disks and it does not work for some reason, dvd player says no disk, has anyone in uk brought some disks online and worked, please tell me where to get them, Thank you
Hi guys, do you have a Morrison store near you ? they have an offer on, buy 10 get 10 free (Maxell)£7.99 also Argos have a drum of 50 Maxell for £24.99 these disks will give you no problem, those Vivastar and other cheep ones are not reliable.
<< As for the other questions, take a look to your left at the list of available help-
Hi
Well that's something I cannot answer I don't have that model, but I have used other disks for music cd's for friends and quite a lot of them never work on some players.
Also the other cheap ones in Argos work fine on my Sony but not on a friends, at the end of the day the Maxell work on everything we have tried. BUT ! no guaranteeSame with TDK they are also no problem
love this player, i just tried some maxell cdrw and the love thing didnt work, i tried 1 song and about 1 min of videocd. Does the mpg i convert have to be done all or can i call inbetween while converting using tmpenc
Hi
Sony player is a DVP-NS400D, other models that friends have got are JVC,Sony, Philips they all play the Maxell disks I made, but CDR not CDR-W
I dont think CDR-W at the price is worth having, after all what is the cost of the product you are putting on the CDR -
if the sony dvd players your friends have are older than the X25 series then i believe they can play majority of cdrs, i have a 725d and i think they can only play a few selected disks, due to the lasers, thats why i need people who have these, what disk it will play definatley, i appreciate your help in previous posts, as u seem to be the only one replying
Hi
Well what have you tried ?, Even those poundland disks are good (2 for a pound)
Apart from the VCD, for many years now I have been using the TDK and Maxell for data, when ever I changed to cheap ones some people with cd roms could not read them, but nobody I know had any probelms with Maxel or TDK.
What are you using to make the VCD's ?
When you made a music cd did you "Close" the disk, remember they wont work if you dont. They will play on a PC but not a stand alone CD player, I guess its the same for some DVD players.
If you make a short movie with TMPGENce you are loading in a PALVCD template ? if you stop it after a few min, as long as the burning softwear does not complain then I guess that short Mpeg will be ok. better to chop out an AVI and convert that if you just want a test.
<font size=-1>[ This Message was edited by: letmeinforgodsake on 2001-08-27 18:28:03 ]</font>
