I'm currently using an ASUS E616 16x DVDROM drive and Power DVD as the software player.
For a couple of DVDs that I own; the software is not able to play it back giving the error above. I wonder if any other users face the same problem and if they have managed to solve it.
I've tried playing the discs in other drives with mixed results; some will and some wont.
Can you guys help me out?
I have a similar problem with Power DVD and SVCD's. DVD's play fine. No ideas why though...
You could try a different price of software to establish whether it is your drive or PowerDVD causing the problem. Go to download.com and pick yp a freeware DVD player. -
As a matter of fact I tried WinDVD and MSIDVD both with disappointing results. I tried using another system using different drives; some worked; some didn't. Could it be a motherboard/hardware issue or an OS issue?
unable to format external hard disc drive
By skorpinok in forum ComputerReplies: 9Last Post: 17th Aug 2011, 16:35 -
Unsupported format or damaged file -> ?
By ermetekos in forum EditingReplies: 1Last Post: 31st Mar 2010, 11:56 -
Cannot burn to a DVD disc and DVD RW-drive changed to CD-drive after copy
By coody in forum DVD & Blu-ray WritersReplies: 0Last Post: 13th Sep 2009, 04:18 -
Unsupported FLV codec or format
By lovyagin in forum EditingReplies: 25Last Post: 11th Dec 2008, 23:13 -
Premiere 6.5 - unsupported compression format.
By vodmare in forum EditingReplies: 3Last Post: 28th Jan 2008, 16:51
