What is the best way to convert AV's with AC3 sound into mpg? VirtualDub can't extract the audio information into a wav file. I was told to use GraphEdit, but can't get it to work or find a description of the filters to use.Isn't there a better way?
Set Audio to direct stream copy and save the "wav". Rename the "wav" to file.ac3. Load this into HeadAC3he and convert to wav (or .mp2) depending on your preferred method.
You can get HeadAC3he from http://darkav.de.vu/ Any problems running it - then make sure you have correct .dlls to suit your CPU (also from the above site). -
Here is the guide
http://www.vcdhelp.com/forum/userguides/91588.php -
Thanks. It worked, and fast. No lets hope its in sync after encoding the SVCD.
But i will also check the GraphEdit approach and compare the sound quallity.
I had good success using Goldwave to extract wav audio when other prog's wouldn't.
"Art is making something out of nothing and selling it." - Frank Zappa -
:P Both ways work and deliver a 700MB wav in minutes (with a 266+ LoL). Qallity equals and its in sync (at least SVCD's, VCD's are allways junk if burned with WinOnCD). So it's a question of taste. Thanks for all replies. Jim over and out
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 21:53 -
Convert AVI with H264 and AC3 to AVI with XVid and AC3
By ashwin.terminator in forum Video ConversionReplies: 4Last Post: 26th Jul 2009, 11:17 -
AVI to AC3 conversion question --Aftern and FFMPEG issues
By eclipse95 in forum AudioReplies: 3Last Post: 9th May 2009, 01:50 -
converting mpeg2/ac3 and avi/ac3 to avi/lambmp3
By corumz in forum Video ConversionReplies: 2Last Post: 17th Sep 2007, 09:32 -
AC3 mono to AC3 2 channel conversion help
By efiste2 in forum AudioReplies: 1Last Post: 21st Jul 2007, 13:06
