the movie.avi i got works find as an .avi file (video+audio matches) but when i try to convert it to mpeg. (THe audio was way off from the video.)
Im trying to make it so the video and audio matches in a mpeg file.
I used VirtualDub1.4 to take the wav(uncompress). Then use TGMPEnc ...etc
My mpeg file (audio and video doesnt match up)
Yes, my Avi works on Media player
Didnt try VirtualDub to fix the avi yet (keyframe flag) beacuse i dont think thats the problem.
I have made find working mpeg files b4 but this is my 1st time having this problem
is there any other way to set it so that i can convert with matching audio and video (mpeg file)
Did you use this method to extract the WAV...?
http://www.vcdhelp.com/virtualdubaudio.htm"Today is only yesterdays tomorrow" -
I did read your original post and I only mentioned the link because sometimes folk don't set the compression and convertion settings correctly (as per the link).
First try DivFix to see if it spots any bad frames.
If it does....download this version of Virtualdub:
http://www.digital-digest.com/dvd/downloads/virtualdub.html
(scroll down to the "Mp3_Freeze" version).
Open movie > Video > Scan for bad frames.
Remove bad frames.
Re-Stream AVI"Today is only yesterdays tomorrow" -
I'm a little confused here, I might be having a similar problem, when I encoded a DivX to SVCD using TMPGEnc it came out with the video being unsynced with the audio. The audio was the proper length, but by the end the video was about 20 minutes slower then the audio. Any solutions?
Yeah.....
Use the method in my first post."Today is only yesterdays tomorrow"
avi.NET sound problem in Interleaving AUDIO with VIDEO muxing
By ntiki in forum Video ConversionReplies: 4Last Post: 13th Mar 2010, 16:34 -
Problem ripping a movie to avi with AutoGK, fast motion audio/video
By Mr. SoAndSo in forum DVD RippingReplies: 1Last Post: 7th Oct 2008, 11:57 -
Problem ripping a movie to avi with AutoGK, fast video/audio
By Mr. SoAndSo in forum Newbie / General discussionsReplies: 1Last Post: 7th Oct 2008, 11:54 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 00:23 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22
