upon viewing captured footage i can not visually tell if there are any frames dropped. how can i be sure my video is intact? is there a utility of some sort i can use to check?
What you have to make sure is that the frame loss that happened is spread out and not concentrated in one area. On an average loosing 1 frame for every 1000 frames is normal and has not visible impact on the video. You can check out the lost frames in VDub. After you finish capturing, open the file in VDub and in the File options you will see "Skip to next Dropped frame". Use this to see if the dropped frames are together or spread out. Hope this helps.
High Quality Capturing with Little Frame Loss in VirtualDub
By monsoon01 in forum User guidesReplies: 65Last Post: 18th May 2013, 22:33 -
MKV & Adobe premiere: Best method to import without quality loss
By libjoe67 in forum EditingReplies: 34Last Post: 19th May 2012, 15:34 -
Stop Motion Animation Frame by Frame Capturing
By Fary4u in forum Capturing and VCRReplies: 9Last Post: 5th Jan 2012, 16:49 -
old way of resizing mp4 with little loss of time & quality
By visible0 in forum Video ConversionReplies: 0Last Post: 15th Apr 2011, 00:13 -
Frame capturing from video file
By igorek in forum Newbie / General discussionsReplies: 4Last Post: 21st Jan 2008, 02:51
