I have a Sony DRU-500A, using a Radeon 7500 video card. My computer has 512 MB of memory with a 1.2 Gigahertz processor. I have over 80 Gigs of space available.
I am trying to capture VHS and laserdisc images to MPEG-2 images to be burned on DVD..
However, the capture program (Sonic MyDVD 4.0) often and unpredictably will suddenly read "MyDVD cannot detect a signal on the selected video source. Please make sure you have a device connected and that is a NTSC device" even though there is clearly an image on display. This occurs whether I use a high quality S-VHS cable or composite cable.
The only reason I prefer capturing video on Sonic MyDVD is because I can insert chapter stops. I can't do the same when I capture using the Radeon video card capture program (which incidentally, captures video great and can detect a signal with no problems at all).
Any ideas on what to do? Can you recommend a program that will allow insertion of chapters after the MPEG image has been made?
Thank you!
Diesel
I have the same program and I had the same problem. From what I read on their website, there are only two capture cards that MYDVD will read to capture. ATI and Dazzle.
So needless to say I am a little upset at that. -
That is hella annoying, isn't it? Does this mean I have to get a new video card? I'd rather get another program that allows me to capture and insert chapter stops than give Sonic MyDVD any further support.
VirtualDub Analogue Video Capturing Problems
By Dr Gonzo in forum Capturing and VCRReplies: 17Last Post: 22nd Sep 2011, 11:27 -
problems capturing with dazzle DVC100 and s-video no color
By rekotc in forum Capturing and VCRReplies: 14Last Post: 23rd Dec 2010, 05:56 -
Problems capturing analog video from VHS tapes
By jdwmba in forum Capturing and VCRReplies: 8Last Post: 15th Mar 2008, 18:52 -
Problems with Roxio MyDVD Basic v9 and other questions
By ForgetSun in forum Newbie / General discussionsReplies: 1Last Post: 18th Dec 2007, 03:29 -
large file size when importing small video clips into Sonic MyDVD
By artistream in forum Newbie / General discussionsReplies: 2Last Post: 1st Nov 2007, 20:48
