First how many .vob's can u have in each title to play properly??
Second is there any way to first combine 2 smaller .vob's into one big .vob but also have a chapter break between ther 2 of them.
Please Help
You can have 9 vob's per title. Go to the "What is DVDR" link to the left and scroll down for more info like this.
I Personally have a bunch of movies I ripped and had the vobs break at a chapter break. It was easier to make the chapter breaks for SVCD this way. The Wizard of Oz actually came out as 55 vobs for that 1 title.
To fix all of this up I use IFOedit. With that tool I recombine the vobs and keep the chapter points. I do seem to need the origional title ifo file to get this to work. Doom9 has the guides on ifoedit. If I only have the vobs, I use vobedit to pull out the video and audio and then use DVDMaestro to re-author. In the worst case, I can then set the chapter pionts manually. -
I guess if you're gonna take a compliation of VOBS u couldn't really use the original IFO file to combine. So you're suggesting to use VOBEDIT and DVD Maestro.
1. How would I set the chapter points manually and with what program? Maestro?
2. also what other program is similar to maestro...i couldn't get it to work on my computer.
how to demux main IFO pgc title to 1 single VOB?
By deejay.2001 in forum DVD RippingReplies: 6Last Post: 24th Apr 2011, 19:21 -
Multiple title-sets share the same vob's
By kdolan1973 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 17th Oct 2010, 18:52 -
extracting SUP format subs from vob title set.
By davexnet in forum Authoring (DVD)Replies: 2Last Post: 26th Sep 2010, 19:29 -
How do i have 1 title and 3 chapters using the vob files that i have?
By Stupidboy123 in forum Authoring (DVD)Replies: 3Last Post: 18th Mar 2010, 13:00 -
How can I fix the playback time of a title when replace the VOB?
By Massa in forum Authoring (DVD)Replies: 5Last Post: 17th Jan 2009, 13:25
