Hello everyone,
I have a problem that has been bothering (Driving me crazy!) me for a while. I have tried to search for a solution ,but have had no luck so far.Hopefully someone can help me.
The problem that I am having is that when I am watching TV using my tuner card (Leadtek WinFast TV 2000 XP) using PowerVCRII or WINDVR my left speaker audio has the audio of the tv program, but my right speaker has the audio of something else(either static, a radio station or spanish audio). So, I can only use one speaker. Also, I have noticed that this mostly happens with channels above the channel number 50, but not always. I was watching channel 12 the other day and the left channel was in English and the Right channel was in Spanish. The wierd thing is, that if I use the software that game with my Leadtek tuner card this does not happen. I have tried POWERVCRII and WINDVR both software titles have the same problem. The left channel has the TV audio and the right channel has some wierd audio. I have tried to uninstall the software that came with my tuner card, but then I get no sound when I open PowerVCRII. I opened device manager and noticed that the drivers for the tuner card are WDM drivers. I am not sure if this matters, but the tuner card is also an FM tuner. Any help would be greatly appreciated. Thanks![]()
I have the same setup (WinFast card & PowerVCR II) and have not noticed this type of behavior. Have you upgraded your WinFast card with the latest driver set? Probably an obvious answer, but it did fix some other strange anomolies I had.
Thanks for responding Alshadin, I believe I am using the latest driver (version 5.13.1.243). Also, it does not happen with all the channels just some of them and it does not happen if I use the Winfast PVR software. Try scanning all your cable channels to see this happens. I just tried it again and some channels have a radio station or static in the right channel. Also, are you using a creative labs sound blaster audighy card?
I checked all my channels and every one has the correct audio. My sound card is an extremely old Diamond Monster Sound MX300.
Good luck on finding out what the cause is.
Intervideo WinDVR 3 wont record more than 10 minutes
By goshtin in forum Capturing and VCRReplies: 1Last Post: 8th Feb 2012, 14:11 -
About windvr and easygrabber 2.0 capture.
By MidnightMike in forum Video Streaming DownloadingReplies: 3Last Post: 15th Dec 2010, 17:32 -
windvr 3 and no sound
By goodtilltomorrow in forum Capturing and VCRReplies: 6Last Post: 12th Oct 2008, 16:34 -
TV Tuner / Capture Card - WinDVR 3 no Audio after Windows Vista install
By buzzsaw in forum Capturing and VCRReplies: 20Last Post: 12th Oct 2008, 15:06 -
WinDVR Input disappears while recording
By jacx3 in forum Capturing and VCRReplies: 2Last Post: 24th Feb 2008, 11:39
