Hey
I have a slow computer and I am going to upgrade the processor from 400 to 1.xx whatever the motherboard can handle.
Now having said that I was wondering if I should up the RAM ?
It's 256 now
I know what ram stands for but:
What is the benifit of uping the ram anyway?
Thanks in advance
VCD4ME
Results 1 to 10 of 10
We were all NEWBIES once and the only stupid question is the one that's not asked?
I think one of the key things is to be able to run more apps at the same time. Less RAM can lead to more reading and writing from the hard drive which can slow things down too...
What really sucks is if you do not have enough ram to hold everything you have open with computer will create a file of your hard drive as a secondary source for ram. When it uses this file is is much slower that the ram it self. Thus the more ram you have the more you computer has to play with. What is really nice is if you have enough ram and you can create a ram drive. Ram drives are much much faster than your standard hard drive. It's great for things you want done quickly. Because the faster a program can gain access to your data the faster it can complete its tasks.
thanks you guys
WOW
I have never read better reponses in my life.
you explained it in laymans term so I could understand it.
ONe more question
How does 512 sound or should I go for more?
Thanks again
VCD4MEWe were all NEWBIES once and the only stupid question is the one that's not asked? -
if you got windows 95/98/Me that's about as far as you can go. if you got xp, then i think there's no limit.
conquest are you saying there is a limit of ram if I am using 98se?
My motherboard specs say max of 1024 ram.
Thanks in advance
Don't remember exactly, but there's an OS limitation on system RAM with Win9x/ME.
Regards.Michael Tam
w: Morsels of Evidence -
According to M$ Win9x RAM capacity is 768MB.Your mobo may support 1024MB of RAM but that is for NTFS or Linux.
Here's some recommendations:
http://tweakhomepc.virtualave.net/memory/vcache.html -
Thanks for the heads up guys
I'll check windows to see about the exact amount of ram.
Signed
Question on DDR2 RAM
By SE14man in forum Newbie / General discussionsReplies: 6Last Post: 5th Aug 2011, 07:01 -
Window 7 Usable RAM question
By SE14man in forum Newbie / General discussionsReplies: 8Last Post: 10th Apr 2011, 07:19 -
Simple Hardware question's on Ram and its support.
By avengerevenge in forum ComputerReplies: 2Last Post: 8th Jul 2010, 08:35 -
RAM question
By mvp in forum ComputerReplies: 3Last Post: 7th Jun 2008, 15:03 -
Question about refreshing DDR RAM for video application.
By SingSing in forum Video ConversionReplies: 7Last Post: 13th Aug 2007, 10:41
