Not my rip, but trying to encode Minority report AVI using TMPGEnc. This AVI encodes fine using Nero, (VCD format )so everything is there. I want to modify it, so I tried encoding it with TMPGEnc. I can't find a valid Audio input file. The video will encode properly. Minority report property's indicates it is DIVXMPG4 V3, and the audio bit rate is 192kbps. I'm a Newbie at this....
found the answer. Changed the Direct Show Multimedia File Reader to priority 2, and then got a valid audio file.....
Output file is way bigger than input file in Virtualdub
By sasuweh in forum Video ConversionReplies: 31Last Post: 10th Oct 2013, 17:25 -
TMPGEnc Authoring Works 4 input 264 not working
By BobAchgill in forum Authoring (DVD)Replies: 4Last Post: 18th Sep 2011, 09:51 -
Input file is not an AVI file!... Uhhh, yes it is.
By joemacd in forum RestorationReplies: 3Last Post: 9th Apr 2008, 08:52 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 08:59 -
TMPGenc and audio file
By JosieB in forum Video ConversionReplies: 10Last Post: 27th May 2007, 04:33
