I've got this weird problem converting an AVI to SVCD. I've been making VCD/SVCD's for a couple of years now and never had a problem like this.
Okay AVIinfo says the file is:
Codec: DivXMPEG4 v4
Four CC: DIV4
And it plays perfectly fine on the computer.
I load it into DVD2SVCD put in all my usual settings and hit Go! The audio goes through fine then it loads CCE goes through the encoding, then it joins everything together then says finished.
When I play the new mpg file the sound comes through fine but I get a black screen with red writing "Avisynth: caught an access violation at 0x16fe83b7. attempting to write to 0x44f2e700"
If I use Tmpgenc to frameserve to CCE the resulting file ends up all garbled and blurry. I also get this result if I use Tmpgenc by itself.
I've tried different codecs the latest XVID, Nimo, FTTshow none seem to make a difference.
Any suggestions would be great. Thanks.
PS. Oh, almost forgot I'm using CCE 2.62, DVD2SVCD 1.1.0 build 1a and the latest Tmpgenc.
Lots of Trouble Converting FLV to AVI
By elykl335 in forum Video ConversionReplies: 5Last Post: 27th Feb 2012, 16:06 -
Trouble with Ripped DVDs/converting .VOB to .AVI
By research in forum Video ConversionReplies: 1Last Post: 15th Jul 2010, 16:42 -
Trouble converting avi to dvd
By illyad in forum Video ConversionReplies: 1Last Post: 18th Dec 2009, 09:34 -
Trouble converting OGM to AVI in AllToAVI
By m93 in forum Video ConversionReplies: 8Last Post: 21st Jul 2008, 19:21 -
trouble converting Quicktime mov. to avi (on windows XP)
By pifkel in forum Video ConversionReplies: 3Last Post: 31st Dec 2007, 05:19
MPEG4 v4
