Using Ifoedit I strip the movie out, but it is sometimes slightly bigger than 4.3 GB.
Is there any feature in Ifoedit that could reduce it a little more?
Sometimes it comes out between 4.4-5 GB. There is no way to burn that on DVD!![]()
If you've stripped everything out that ya don't want, subs, languages, etc..., and the main movie is still bigger than 4.3 gigs, afraid ya gotta encode it, or split to two dvd-r's
actually, it would be "re-encode"... At a slightly lesser bitrate, just enough to make it fit.
If it's 4.5/4.6 you could strip out the ending credits and that might make it small enough. The end credits are typically 200-250MB's.
Use Vobedit to demux the last vob in the set. It will create a set of cell files,the last one is probably the credits. Delete it and remux the remaining cells with DV Tool back into a vob.
LCD Monitor Screen Size, bigger isn't really bigger?
By Des in forum ComputerReplies: 13Last Post: 27th Dec 2011, 14:13 -
How do I burn a DVD bigger than 4.7 GB?
By Rayroshi in forum Authoring (DVD)Replies: 12Last Post: 29th Nov 2011, 07:02 -
Slightly cracked dvd how to recover. Please!
By boristhespie in forum Authoring (DVD)Replies: 9Last Post: 28th Sep 2010, 23:24 -
Digital 8/Hi8 to DVD, slightly choppy.
By Dixie Paul in forum Newbie / General discussionsReplies: 3Last Post: 18th Jan 2009, 16:20 -
bigger DVD-RW's than 8.5gb??
By cedarhill in forum Newbie / General discussionsReplies: 4Last Post: 18th Nov 2008, 14:46
