i have an iBook, or i can use my dads cube since its faster. heres what i need done.
first off, i am looking into buying an external dvd burner.
i will be getting two DVD+R discs in the mail soon, and my dvd player wont play them. is there anyway i can somehow put those onto DVD-R discs? also, can the apple dvd players play DVD+R? i doubt it, thanks in advance.
I have copied DVD-R to DVD-R on PC platforms, and I also have an iMac which can sometimes read DVD-R.
The key is being able to copy the VIDEO_TS and AUDIO_TS directories off the original DVD. You can then simply re-burn the two directories and their contents to a DVD-R. If you have your two Macs networked and one can read the DVD+R, you can copy the files to your iBook and burn it. -
i just looked at the DVD and the audio_ts folder is just empty, so i dunno whats up there, the video one is about 7.8 GB. This was on a david gray dvd, just for example.
The AUDIO_TS folder will be empty (unless it's a DVD-Audio disc). I copy the empty one to my DVD-Rs along with the VIDEO_TS folder, though I've left it out and the disc still played fine. I think the standard says both folders must be there.
If your Video_TS folder has 7.4GB of data, this must be a two-layer commercial DVD disc (DVD+R and DVD-R can only hold 4.7GB of data). You'd have to rip it and re-encode it at a lower bitrate. I've never really done that. There are many threads dealing with that situation. If you just have 2 DVD+Rs coming to you, then you just need to copy them to 2 DVD-Rs.
Need Help with Panasonic DVD-LS83 or DVD-LS86 8" Portable DVD Player!
By Big C in forum Portable VideoReplies: 3Last Post: 1st Aug 2011, 17:35 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 12:34 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 17:59 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 08:59
