  1. i have a clip and wanna re-encode it.
    but it only have the right audio when i use GoldWave to make the audio(.wav) for re-encoding.
    how can i make the left by using GoldWave??
    plz....and thax a lot.
  2. What you have is a mono audio source, I presume. Encode it as mono and it should work just fine. Encoding as stereo may also work, since the encoder will likely generate the same audio stream for left and right channel. It would also help if you give more info...how are you planning to use the audio? What encoder are you intending to run it through?
  3. i want to convert the clip into mpg then burn it to a vcd.
    i'm using TMPGEnc.
    i've tried encoding a little part.
    i set it as stereo in the setting.
    but it still have only one audio.
    is it possible to make the left audio??
    thax again^^
