I've encoded an SVCD-compatible MPEG-2 file using FFMPEGX (on a 700 iBook), and there are several problems with the file..
a) there are black borders top and bottom that were not present on the original source (they appear below the VHS tracking lines)
b) on fast moving scenes the scenes look extremely distorted.
you can see both problems in the picture below. the top pic is the resulting encoded file, the bottom is my original iMovie DV file.
this was encoded using the default SVCD template in FFMPEGX.
any ideas?
-Mark
[/img]
Results 1 to 16 of 16
Swim with me
And we'll escape
All the trouble
Of the present age
Finally free
When input file is .mov there is no way of turning off the black bars. They are added to preserve aspect ratio. If source ratio is already good, no bars are added. I just encoded a sample 4:3 clip to SVCD NTSC and there were no black bars added. I think I should need your file to check what happens. Can you upload a chunk of it to some ftp site or iDisk?
mark had actually been doing this project on my mac.. so i've made a tiny clip of his original file and uploaded it to my idisk for you to see.
it's like 3/4 of a second long, and still 3.5MB. hopefully it won't be too much trouble to download, and will be long enough for you to work with.
http://homepage.mac.com/triumphsarm/everclearclip.mov
thank you for helping us out with this, we really appreciate your time
[/url]
thanks very much major, i'll give it a go (or get behoovedgirl to
maybe this is something that could be worked on for the next release of the software though.. the seperate audio/video muxing is a tiny inconvenience, if you see what i mean.
great program though!
-markSwim with me
And we'll escape
All the trouble
Of the present age
Finally free
ok i've done everything you said.. i set the quicktime movie to "high quality" and "single field" modes. i changed the file name to dv, and re-encoded it, extracted the audio, converted it to mp2, then muxed them together... and the black boxes are gone, but now i've got a different quality problem...
there's horizontal-only lines across the video whenever there's motion. it doesn't look *as* bad on the TV screen, but they're still noticeably there.
now i had to encode it at 2100 kbit/s and author it as an xsvcd, because that's what it needs to be set at in order to fit it onto 1 CD. otherwise, all the other settings were that of a standard SVCD.
any ideas what could be causing it? thanks again for all your help thus far
Looks like a classic case of interlacing artifacts, try selecting deinterlace in the SVCD/VCD tab.
As below, so above and beyond, I imagine
drawn outside the lines of reason.
Push the envelope. Watch it bend.
Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind.
i just tried re-encoding it with "deinterlace" checked, and it didnt make a difference.
i've also tried different combinations of "not interlaced" "field" and "frame", and toggling VBR in the SVCD options tab, and none of them helped.
this is so confusing, it didn't do this when i encoded straight from the .mov... only after i renamed it to a .dv file. does anyone have any other ideas what could be causing this? i'm absolutely clueless!
if you are going straight from a .mov file, the best way i got to work for svcd was with mediapipe, cause i kept getting the interace artifacts you're getting.
file browser (add file)
qt decode
scale
mpeg2nec set your svcd stuff and you want to set to interlaced bottom field first(if it's dv footage, cause that's the field order for dv footage)
this worked great. i'm not at my home comp so i don't have the exact svcd settings but if you want them i'll post them later.
pants
wooo i think i got it sorted.
i figured out the problem was directly related to the fact that i was encoding from a DV file, cos i tried a few others and it did the same thing.
so i started over and exported the video out of imovie as a motion jpeg A, and set the proportion to 640 x 480. this created a quicktime movie (which doesnt have the interlacing/artifact problems that the DV files did), and it was exactly the right proportions to not make any black bars on the top and bottom or sides when i encoded it with ffmpegx.
thanks again for everyone's help!
How to choose *separate* videos off one DVD for encoding in ffMPEGx
By DrLooby in forum Newbie / General discussionsReplies: 2Last Post: 20th Aug 2011, 21:13 -
Problem with artifacts when encoding to FLV using ffmpegX
By Leon_Cych in forum ffmpegX general discussionReplies: 2Last Post: 30th Apr 2010, 07:57 -
ffmpegX not encoding properly -- fails after 7%
By larrryc in forum ffmpegX general discussionReplies: 2Last Post: 22nd Apr 2010, 14:07 -
(some) MOV's not encoding to MP4 on ffmpegX
By DarkPhoenix77 in forum MacReplies: 2Last Post: 6th Oct 2007, 23:35 -
Strange Flicker in DVD with ffmpegX encoding
By angeloftheodd in forum ffmpegX general discussionReplies: 3Last Post: 2nd Jul 2007, 21:49
