I have been capturing AVI using virtualdub from a HI 8 to AIW 128 pro.
All my settings are the same as always and yesterday, was capturing SAME video, same clips. When I brought into Video Factory, the clips said FIELD ORDER BOTTOM...Thats strange, it always says top.
I rendered to avi (and it wanted bottom) so I left that and it was fine. Fed to TMPG and when it said JUDGING FIELD ORDER it selected Field A ? That part is normal but not for a clip that started bottom.
What has changed in Virtualdub on me ? I tried SWAP FIELDS and no change on capture.
Any idea's ?
I think encoders have a hard time guessing field order especially after using filters.
If I have virtualdub perform a 3x3 average TMPGEnc says my NTSC DV is top field first; without the filter TMPGEnc properly indicates that my DV source is bottom field first.
I guess as a follup question: does anyone know whether filters can change the field order of the source video? -
Yes..TMPG can...But not for the better. If the field order is wrong, it is wrong. That is why it is important to keep track.
My biggest issue is on captured ANALOG video like mine, it should be UPPER. Yet, it myseriously switched....DUH. But TMPG did find it better to use upper. Even though my CAPTURE told me lower. Heres the kicker.
I tried encoding BOTH ways. TMPG was right.
Just when I thought I had a process down.... At the same time, my best DVD player is somewhat erratic causing me to second guess my burned disk.
Seems my wife tried to play a disk....While another ws already loaded. Door closed, loaded, SCREECHED and she quickly got it out.
Hasn't been the same since...SIGH
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 01:38 -
Reconciling different Field Order
By vegasarian in forum EditingReplies: 8Last Post: 14th Mar 2009, 12:43 -
field order and cce
By cd090580 in forum Newbie / General discussionsReplies: 3Last Post: 17th May 2008, 17:11 -
Field Order Problem?
By GordRocks in forum Authoring (DVD)Replies: 3Last Post: 4th Mar 2008, 10:19 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 17:14
