I just got a dvd writer over the weekend and am starting to try and rip dvd to dvd-r. I have done vcd and svcds in the past but am not that experienced. I am trying to rip the movie Almost Famous. This is the tutorial I am trying to follow: http://www.vcdhelp.com/forum/viewtopic.php?t=109346
I start up DVD Decrypter and have it set to file mode and let it choose the main movie automatically. It rips 1 ifo and 6 vobs. The movie is about 6gb. I then open up DVD2AVI, open up the first vob file and then set all the auto options to demux. I then go to save project and let it do its thing. THe problem I am having is DVD2AVI is only creating the d2v file, its not making the ac3 file so therefore I can't go on any further. I have tried other tutorials as well and I still can't get the ac3 file to be created. Hopefully someone here can help.
Also, I use a 16x dvd-rom to do my ripping and it only rips at 2x, any ideas as to why?
Originally Posted by vwTurbo
Track number -> 1
Channel format -> Dolby Digital
Dolby Digital -> Demux All
Some new DVD-rom's are locked 2x ripping speed... also many dvd-writers are locked to 2x ripping speed... 8)
Zzzzzzzzzzz -
ok well that kind of worked. now i am having the same problem as the post down a few from this one. now it created 2 ac3 files.
AC3 T02 3_2ch 448kbps DELAY 0ms.ac3
and
AC3 T03 2_0ch 192kbps DELAY 0ms.ac3
Shouldn't there be a 6ch one?
In DVD2AVI i have Dolby Digital set to Demux All Tracks and track number is set to 1. -
nevermind i just read in a similar post that DVD2AVI creates to ac3 files one 3ch and one 2ch so i think that my problem is solved. will i have to merge these 2 ac3 files into one? and if so, how?
Use this one;
That's the DD 5.1 (or 6 channel) file. DVD2AVI just displays it as 3_2 ch to confuse you -
Originally Posted by ghoster
Zzzzzzzzzz
Split, join, create silence of an ac3 file
By phate89 in forum AudioReplies: 6Last Post: 16th Jul 2011, 13:34 -
Trying To Create An Ac3 File W/virtualdubmod?
By jwmghf in forum Video ConversionReplies: 0Last Post: 18th Jun 2011, 15:46 -
How to create M4V files w/AC3+AAC from M4V w/AC3 only??
By williamlondon in forum MacReplies: 4Last Post: 5th Oct 2010, 16:15 -
VOB2MPG won't create the mpg
By Heibi in forum Newbie / General discussionsReplies: 6Last Post: 6th Sep 2008, 17:34 -
DVD won't read...won't create avi thumbnails
By ru5ty in forum DVD & Blu-ray WritersReplies: 6Last Post: 27th Jul 2007, 20:04
