Everytime I use FLASK the end product says that its 95.6% (somewhere along that line) done. The movie has finished except for some of the credits. I don't have a problem with that, but would like to have it all!
My seconds I use are MORE than enough for the entire movie, but I still get the same result.
PLUS, I get an error at the end say the "The movie may not play"....
FInished Multiplexing...
The movie DOES play, but hate to see ANY type of errors at the end obviously....especially when the decoding DOESN'T finish at 100%.
ANy suggestions? Thanks.
I don't have that problem with FlaskMPEG but then, I don't use the included bbMPEG encoder...
How did you rip your VOB files??
Regards.Michael Tam
w: Morsels of Evidence
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
