Hi. I have an DIVX/AVI in NTSCFilm that I converted to XVCD 2000 CBR using TMPGenc. I used the NTSCFilm VCD template and then unlocked it to change the resolution to 640x480. When I play back the VCD in my Panasonic RV31 DVD player, the video seems choppy sometimes during fast motion. How do I get rid of that to get a smooth movie?
Could I convert this to NTSC to get a higher framerate?
Two possible problems.
(1) Your DVD player simply can't handle your XVCD settings (none are designed to I hope you realise)
(2) Your DVD player doesn't play back NTSC-FILM VCDs well.
It is hard to tell what the problem is if you have some many variables.
Regards.Michael Tam
w: Morsels of Evidence
Jerky clips
By kaikaiyeung in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 7th Aug 2009, 04:05 -
Jerky playback on TV from PC using TV Out
By digidude in forum Software PlayingReplies: 0Last Post: 30th Dec 2008, 18:26 -
Video is Jerky after NTSC DVD to PAL VCD Conversion.
By milindb1 in forum Video ConversionReplies: 14Last Post: 10th Sep 2008, 03:22 -
Video is jerky
By arnie22112000 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Apr 2008, 01:49 -
Jerky motion
By davidk21770 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 24th Oct 2007, 18:41
