Hi all I No How To rip A DVD-9 to get in on one DVD-5 Can anyone tell me is there a way to copy the menus And Chapters to use with the rip
on one DVD-5
THANKS !!!![]()
Try using dvd2dvdr(this lets you pick chapters, if you want to use ifoedit), encode the main movie to leave enough space to keep the menus, extras and chapters. With the resulting m2v and ac3 files, author with maestro. Then copy the authored movie vobs(renamed to the original vts_xxx.vobs) back into the dvd structure (deleting the originals) and then run ifoupdate on the original and authored ifo files. This will keep everything.........hopefully
If the movie is too big and would suffer from encoding, just encode the exras
This is how I go about it;
1) Use chapter extractor and make a .chp file to run in maestro
2) Run dvd2dvr to encode what you want.
3) Author resulting files with maestro (inserting your already made .chp file)
4) Rename authored vobs to original and copy over to dvd structure
5) Run ifoupdate
6) Burn with ya favourite proggy
THANKS ALOT FOR THAT !!!!!
Will give it a try
I BE BACK IF NOT (LOL)
THANKS AGAIN
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 167Last Post: 8th Dec 2022, 02:44 -
dvd menus... are they normally 16:9 or 4:3?
By extent in forum Newbie / General discussionsReplies: 12Last Post: 18th Dec 2009, 21:06 -
Magix Movie Edit Pro Menus and Sub-menus
By gayclarke in forum Authoring (DVD)Replies: 8Last Post: 11th Aug 2007, 10:07 -
Help with DVD Menus.
By de8212 in forum Authoring (DVD)Replies: 13Last Post: 3rd Aug 2007, 07:05 -
4:3 and 16:9 menus on the same dvd, possible?
By Idofex in forum Authoring (DVD)Replies: 9Last Post: 24th May 2007, 19:49
