Can it be downloaded or is it already in my system and needs to be enabled?
I had it before i formated my drive but now is gone.
I have Huffyuv allready instaled. The problem is, before i formated my HD i was able to capture in DIVX at VCD PAL resolution without frame loss by selecting YUY2 as Image format. And now i can't! So i guess the problem lies within this YUY2 stuff.
If you are using virtualdub select the use set enable rgb filtering think option in virtualdub
YUY2 vs RGB24 vs Y800
By 201flyer in forum Software PlayingReplies: 40Last Post: 28th Apr 2011, 06:11 -
Convert YUY2 to RGB
By jrivord in forum Video Streaming DownloadingReplies: 8Last Post: 19th Aug 2010, 10:21 -
Which audio codec I need to enable for playing "cook/ffcook" audi
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 18th Sep 2009, 23:10 -
YUY2 Codec for Quicktime?
By EZ-Fan in forum Software PlayingReplies: 1Last Post: 12th May 2009, 08:07 -
YUY2 Vs. UYVY Capture
By W_Eagle in forum Capturing and VCRReplies: 2Last Post: 11th Jul 2008, 10:15
