  1. On one of the guides from making a DVDR from a DVD it says when burning with Nero use the DVD UDF/ISO function. I usually just use the DVD VIDEO function and compile all of the files from my VIDEO_TS folder on my desktop, to the VIDEO_TS folder Nero makes for you when you select DVD VIDEO. Does it matter which function I use? What is the difference between the two? I have the latest version of Nero. Thanks
  2. I had A proplem Using The dvd video one of my dvd players alba 114 did not like it and the cyberhome did so i tryed the other way. but the same thing happen but the other way round the only program that i found worked with both is prassi primoDVD 2 both dvd like it i hope this helps
  3. I also had a problem with the dvd video option, and also with primo, both would not allow me to play in standalone, but disc burnt perfectly with the Nero udf/iso function, and played fine in standalone...................weird eh?
  4. Yes It Must be somethink to do with the wait nero writes the disk but i have try prassi primoDVD 2 on a few dvd players and had no problems
  5. thanks for the replies. My Standalone DVD Player recognizes both formats from both DVD Video and UDF/ISO. I guess I am just lucky. Basically from the sound of it, it seems like you are saying to basically just use whichever method works, right? Being that they both work for me I can continue to use DVD-Video I guess. Thanks for the help. I just wanted to make sure there wasn't some big difference between the two methods.
