Hi, and sorry by my english, I'm spanish guy. CVD quality is very good but I would like to use it with VCDEasy and it isn't possible, (format doesn't recognized in VCDEasy). it'll be very important this format for the future, why doesn't support it, I select the SVCD option but it's incompatible. Anybody can tell me if it's possible to work with this format and what can I do to get work it?
Thank you very much. Best regards
Results 1 to 9 of 9
In the newer version you get a message box with the compliance details and the details of your file asking whether to accept it anyway. This is even with the compliance check box ticked. I've ditched using SVCD format almost completely for CVD. I agree it would be nice if it didn't complain like it's an invalid format but it should work regardless. Use puertorican138's solution if you can't get a more recent version.
Raavin
Basically, VCDImager doesn't make CVDs. It makes VCD and SVCD. CVD is mostly like SVCD so it tends to work anyway but in reality, you are only making an XSVCD with CVD video specs. There are some other minor differences between SVCD and CVD beyond the video specs.
Regards.Michael Tam
w: Morsels of Evidence
adam can probably answer this better than me as I don't use this particular proggy, but I-Author may be as close as it gets...
Regards.Michael Tam
Well, the answer to that depends on what the exact requirements of CVD are. I remember there used to be a good description in the VCDImager documentation, but I think its been long since removed in the latest PDF releases, and I don't remember the differences besides the obvious resolution difference.
I think the Volume ID reads CVD instead of SVCD or Super_VCD? This is changed easily enough in any authoring program though.
I think maybe some of the other files on the disk have different filenames as well, and no I-Author doesn't allow you to make this modification.
I-Author supports VCD, SVCD and SuperVCD. Super VCD is the format we all know of, SVCD is a slightly modified version which is used for increased compatibility with hardware players that don't specifically support Super_VCD. The main difference is that the mpg file is stored in the Mpegav directory instead of the Mpeg2 directory, basically in an attempt to fool the player into playing it like a VCD.
Like Vitualis said though, besides resolution, the differences between CVD and Super_VCD are probably negligable. I think the only hardware player which would require true CVD compliance would be a CVD only hardware player, which would probably be very hard to come by.
I think that the offsets in the MPEG stream are different in CVD compared to SVCD (actually, TMPGEnc used to -- ?? and still does ?? -- make MPEG-2 streams with CVD style offsets rather than SVCD).
I think that the MPEG stills are ?? different too in terms of headers but I don't know for sure.
And then there are some other minor differences like the ones that adam just described above.
I've played with I-Author but have not touched it for a very long time. My recollection of it is that it seems to make a "SVCD" that was kind of "CVD-ish" -- and though this is complete speculation, perhaps it was released during that interim period when CVD was out and about (and being pushed by C-Cube) while SVCD had just been ratified...
Regards.Michael Tam
Amateur Question: My DVD9 doesn't support AC3 Audio
By Keziapurrs in forum AudioReplies: 15Last Post: 10th Jul 2011, 19:03 -
AVI won't play. VLC say's doesn't support "IV50" Format. All codecs present
By Sikander in forum Software PlayingReplies: 2Last Post: 21st Feb 2010, 07:40 -
Machete 3.3 released - now with FLV format support
By MacheteSoft in forum Latest Video NewsReplies: 1Last Post: 7th Jul 2009, 12:12 -
Firefox3 doesn't support realplayer plugin
By toddfv411 in forum Video Streaming DownloadingReplies: 4Last Post: 9th Jun 2008, 18:27 -
How can I install PPro2 on system that doesn't support SSE2?
By Sean_ve99 in forum EditingReplies: 1Last Post: 26th May 2007, 07:33
:P
