My DVD player plays both NTSC and PAL VCD's (I am in Australia), but I was wondering which format is best suited when burning VCD's? Or just which format is better all together?
Cheerz.
A fellow Aussie!
Here, you should probably go with PAL. Most of the source material you'll be dealing with is in PAL an you shouldn't be converting standards for no good reason. Also, although it all multisystems here, most equipment will probably still do PAL better.
If you source is in NTSC, then make an NTSC VCD.
Regards.Michael Tam
w: Morsels of Evidence -
Haha Aussies rule!
Cheers for your advice man, it helped a lot. Just one thing, how do I know what format my source movie is if it is a downloaded AVI or DivX etc.?
Thanks Bro. -
25 fps = PAL (for all intents and purposes)
29.97 fps = NTSC (for all intents and purposes)
23.976 fps = NTSC -FILM
Anything else and you are in a bit of a bind as you will have to convert the framerate. Be logical. If it is 15 fps, then use NTSC (as 15 x 2 is pretty close to 29.97).
Regards.Michael Tam
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 10:40 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 12:30 -
PAL aspect ratio 2.35 format to 16:9 NTSC
By chowa in forum Video ConversionReplies: 7Last Post: 2nd Feb 2008, 18:16 -
using pal material to work in an ntsc format
By rapidondamove in forum MacReplies: 2Last Post: 7th Jun 2007, 17:22
