Is there any good way to convert a 20.00 fps source to 23.976 or 25 fps? Would simply setting the framerate in TMPGEnc to one of those produce, shall we say, undesirable results?
I've converted 19 fps divx to 29.97 fps mpeg2 (svcd). It works fine as long as you don't get greedy and inverse telecine it to 24 fps.
You should run a 10-30 second capture test using Source Frame Range filter to make sure that it plays at the correct speed. It's as simple as changing the video stream frame rate to 29.97 in tmpgenc 12i.
Issues Converting from 25 fps to 29.97 fps
By Klagar in forum Video ConversionReplies: 7Last Post: 13th Jul 2011, 11:30 -
Converting 60 fps to 30 fps
By kelcey in forum EditingReplies: 11Last Post: 24th Jul 2008, 03:15 -
Converting 23.976 fps to 29.97 fps
By wasimismail in forum Video ConversionReplies: 8Last Post: 14th May 2008, 18:26 -
Converting 23.976 fps to 29.9 fps
By zanos in forum Video ConversionReplies: 4Last Post: 13th Apr 2008, 09:03 -
FPS..NTSC & PAL Standard Cinema Film/Digital
By flamingo in forum TestReplies: 0Last Post: 9th Nov 2007, 08:30
